Errr... Will work fine on 8x
What pins you on bout?
+1
I was using 3 for some trifire action and one of those cards had to be @ x8
if you look at a pcie card, there are two sets of pins,
towards the IO shield there is a small set of pins
and then there is the longer stretch of pins the presumably power the card
so if you look at the back of a mobo and find an 8x pcie lane, it will only have metal pins running half the length of the pcie slot
So this new crossfire technology, what pins does it use to communicate to the other card? because some mobos wont have all the pins available in the pcie slot
and Kaapstad, if you were to put a fourth in your rig, would it then need more pics to talk across? so would it need to be a 16x mobo for quadfire?
additionally, i can imagine some top end motherboards for ln2 benchers or something, making their pcie slots electrically isolated for safety which means that the cards cant talk over pcie
Quadfire 290x
Are you going to be testing out 780ti aswell kaap?
Such a **** take. Two black screens already today.
If i hadn't redeemed that bloody BF4 key (not that i actually got the key for 8 days after i redeemed it, and had already bought a copy by then, so haven't actually used it), i'd have got a TI by now.
Such an, utter, utter **** take. No working machine, only option to go through RMA process which is unlikely to find a problem and will take ages.
If i just got SOME communication from Sapphire or AMD I'd be happy, but totally ignored. It's like they know about the problem but don't want to discuss it...
Yeah that sounds pretty sucky, it seems to be a driver related issue though, at least according to some of the posts I've read. Are you running at stock speeds?
I was getting some black screen errors a few days ago, but then BF4 did some server side patch or something and I played 4 hours solid without a single glitch.
Very sketchy tbh.
Been lucky i think and not had any blackscreens other than when pushing the memory too far.
Unfortunately my Sapphire 290X keeps crashing out of BF4 under stock settings, I then notice the fan going like the clappers.
I'm going to send it back unless there's a quick solution that will help run stable.
Will probably replace with a 780 instead![]()
Are you seeing problems in other games or just BF4 ? Maybe try a different browser to launch it might help maybe I hope![]()
Sorry to be a noob, but what do you mean? Are the two DVI ports on the card different somehow? I use the top on, but am using a dual-link cable.
