- 6 Aug 2009
- Wales
Is that a Crossfire bridge? i thought the 290s didn't have them?
So what the hell is that on his cards? I'm questioning you knowledge mind 8Pack, i know they don't, i have one, but looking at the pics on the previous page, it looks like some sort of Multicard CF bridge.
AMD to Bundle BF4 for free with all R9 cards
While a Battlefield 4 has been exclusive to the lovely R9 290X, it seems that AMD are keen to share the love and now the whole range, including the R9 290, R9 280X and even the budget friendly R9 270X will be getting a taste of the action.
Dear Sir
Suggest you update motherboard bios, chipset driver to the latest version. Please also update game patch and AMD application profile driver for your card. Should be software issue. Check this way. Thanks.
Regards
The Quad R9 290x will be integrated in this loop.
-Feser X -Changer 240mm (Push Pull)
-Feser X -Changer 360mm (Push Pull)
-Feser X -Changer 480mm (Push Pull)
-Watercool Mo-RA3 Pro 1080mm (Push)
(2160mm of Radiator)
Kaapstad not sure but for 4 He needs 2. Or one 2000w
I was doing some stability testing yesterday and. Card was pulling 380 watts according to GPUz.
So 4 would pull up to 1600 watts themselves.
Not had much time to test as working till Thursday, once done will give my hole draft of games a blast, Arma 3 works fine, will try different fan profiles (> 47%) to see if that improves it.
(lol just released this is the 290X owners thread)
Well after a failed Linux Lite 1.0.6 install, now have a fresh W7P 64 running, and fished out the other PCI-E power cable for my PSU to have two separate rails running.The R9 290 is now playing ball, no black screens etc.
Lets hope it keeps going.
Regards
C.
