Wasn't exactly being factually serious, but I guess technically, the first caveman to throw a rock at a prehistoric badger from behind a hedge was probably the first camper.
Yeah I wasnt either....
Doesn't always matter, this depends on the gun!
Anyone put this to the test for real?
Helmets are designed to deflect bullets and absorb energy from shapnel. A well designed Kevlar helmet can move the ballistic off centre and change the bullet path maybe just enough to prevent a fatal head wound. They certainy can't stop large caliber rounds from assault rifles at close range. But surely if a ballistic vest can stop a 9mm so too will a heavy kevlar helmet?
Any Military Personnel on here?
I used to do work for SCRDE who amongst other things designed/tested helmets worn by UK troops in the 80s/90s. Its not however my area of expertise but from what I did see in testing some people in this thread are a bit off the mark.
TBH though its not something that you can pin down exactly - while a helmet might stop or deflect the energy from a certain round in testing, in the field in a different scenario with a different set of parameters it might not work so well and vice versa.
Ok then who's up for putting a helmet on and being shot?![]()
Level 3 helmets will easily stop 9mm rounds at very close range.
(the nylon had made a wierd sort of melty shape coming out of the exit hole) but meh you may well be correct
Someone has to step up, my rage has spanned generations of games, I broke a few monitors and keyboard playing UO and CS![]()
ive seen a british mk6 with a 9mm hole in both sides(the nylon had made a wierd sort of melty shape coming out of the exit hole) but meh you may well be correct
liking the game itself but very disliking:
having to unlock everything again (like someone above was saying) - even the same weapons i have already unlocked in BF3 - AGAIN
played for a fair few hours already and only have 1 rifle about 3/4 of its addons, no extra pistols (not even addons yet) it would take many hours to experiment with all the options anyway so is having to unlock them so neccessary? if your game is so dull that its the only way to keep people playing then there is no point in playing it
seems to be too many tanks / helis etc on some levels, I like having them in the game, as it mixes things up a bit, but too many and you just constantly get hammered by tank after tank after tank and it gets pretty dull/frustrating
So whats your opinion? Do you have quantifiables.
) or a tank or heli with engineers following themBTW, how the **** do I leave a group chat on BL, accidentally created one a while ago and joined one recently but I can't exit/leave it at all, tried different browsers etc. I click the X button but nothing happens!![]()
Use BF3 battlelog for that, BF4 BLog is soo borked.
I was mostly involved in the materials (mostly the leathers) used for boots and gloves).
(jking
