I cant think of a better way to spend my Friday afternoon at work![]()
I know its great.
I see JustFlight have a holding page for Revolution-X
<snip/>
http://justflight.com/product/revolution-x
I also managed to get some practice in the old cessna last night (first time in a while), been working on trimming as im still rubbish at it. Also watched a load of aviator90 tutorial videos that someone recommended a while ago. They are very informative.
I still find trimming a bit hit and miss, which I guess is partly down to the simulation and not being able to feel the effects as blue has said below. Not sure how you're setup but I have the trim wheel mapped to a switch on my yoke, which I set to "repeat on hold". If I'm trimming for level flight, I feed in a bit of trim and then start to release pressure on the yoke, if I start to climb I'll hold the yoke at that position and feed in a bit more trim and then release the yoke a bit more. Basically I repeat the process until I'm in level flight. I'm not saying this is the right way of doing it but it works for me (most of the time)
So, daft question, but if P3d comes out this Monday and it blows everything away, can PMDG aircraft and FTX Global be installed (maybe in a slightly questionable fashion) and used? Those are the only 2 addons I really care about to be honest, other stuff is only nice like maybe REX.
Also, does anyone run FSX with triple screens? I've heard that it's not ideal, anyone have any setup tips?
LM re P3D said:Can you please speak about multiple monitor and multi-PC setup for Home cockpits? What is the maximum number of screens we could have? Currently in FSX. its 3+1.
We’ve delivered training solutions with up to 12 screens. With a lot of the advancements of Prepar3D v2 multiple monitors and screens have less of a performance impact, and we’ve also worked to resolve the ‘fisheye’ effect for wide view screens or views spread across multiple screens. If you have a custom setup like this, we also now let you define the horizontal and vertical FOV yourself in your camera.cfg files, so you can now custom-tune and hand-define your FOV to exactly what you want it to be. This was never possible before in a previous product. We invite folks to look over the v2 learning center in any license of Prepar3D v2 to see just how much customization we have added to Prepar3D.
The Plan:-
To fly a light aircraft, VFR from Aldergrove to East Midlands on Vatsim with you guys.
Plan-G Plan:- [You may need to copy text and resave as a .plg file]
http://www.andrewreader.com/ocuk/VFR%20Aldergrove%20to%20East%20Midlands.plg
PDF Flight Log:- [You can print this and fill in the missing details]
http://www.andrewreader.com/ocuk/VFR_EGAAEGNX01.pdf
When:-
I can't do Tuesdays, but will try to be as flexible as I can weekday evenings after 7pm and flexible at weekends.
So those that were/are interested, let's have an agreement on a date:-
Friday 29th November
W/C Monday 2nd December (2nd, 5th, 6th, 7th, 8th)
W/C Monday 9th December (9th, 11th, 12th, 14th, 15th)
W/C Monday 16th December (16th, 18th, 19th, 22nd)
Many thanks,
Andrew.
enjoyed watching your stream while at work yesterday vuvuzela, wish I could have had sound on thoughI did miss the landing as had to deal with people....blah lol
The Plan:-
When:-
Many thanks,
Andrew.
I've had a look at the flight plan and see it takes us through a few controlled areas so it looks like there may be quite a bit of ATC if Manchester and IOM are online. I think I'll need to start some practicing!
I will pretty much follow everyones lead on this, most weekdays should be good for my.
We still ok for tonight blue?
What time you guys flying later?
We were planning for 8pm tonight for some Vatsim practice.
Meet on Mumble then.
Still good for me.
Might not get on later. My little one has developed a bad cold. If I can get her settled and in bed I will join you.
