The Elder Scrolls V: Skyrim - MODS & TWEAKS
For Enchantment. there must be a mod that does that, as SkyRe does it, so I imagine there is also some kind of standalone one. You go to an Enchanter with an empty soul gem and your item, then you pay him based on the size of the soul gem.
Yeah thats what im after! Ill have a search around if the nexus is working again. Thanks.
Think this is as good as ill get. http://www.nexusmods.com/skyrim/mods/17262/?
Enchanters Merchant. - Adds a murchant in whiterun that sells all enchanted items! Feels abit like cheating though lol
Nah thats rubbish all weapons/enchaments are pretty weak.
Oh dear, Downloaded ENB doesn't work too well with RCRN... Lagged to 3fps and it went light dark light dark, woops!
turn shadows to low/med in your skyrim setup start up thingy. ENB uses its own shadows.
turn AA=off
turn AF=off
Turn frame sync to on in the nvidia control panel, the place were you turned on AO.. and while you're at it, turn that back off again as you might be running it twice with the ENB.
if that doesn't work, press shift+enter
scroll down a touch and start knocking off the ticked boxes with FOV, AO, imagelighting etc and see what is causing the problems.
Some ENBs are set up for cards which have larger memory than yours, it's in the enblocal.ini file, can't remember the exact name but it's about gpu memory. change it to 2048.
hope that works.
If not, time to sli :)
Just want to say thanks again to Neil79 for original post for the different recommended mods :), i actualy got around to installing nearly all of them and they look and run great and a big thank you to Wickfut for finaly finding me a ENB that my little 6850 with 1 gig of ram can run :D
[/URL][/IMG]
The only problem i have are torches here is a screenshot
The torch flame looks like it has a static flame effect and a animated flame effect at the same time, candles are ok but appart from that its realy good ;). I think neil should recommend this for people with low end pcs or grahics cards with 1 gig of ram and maybe something a bit more fancy for mid to high end rigs or graphics cards with 2 gig of ram or more
This enb will keep me going now till i can get a new card for christmas, i have been looking at getting a R9 270X with 2 gig of ram or a 7850 with 4 gig of ram and over clock it a bit, gonna pop on over to graphics card forum and see what they suggest for about 150-160 quid :cool:
Ps i forgot to say its the Real Like ENB v0.113, i will defo be using the newer version with enb boost when i get my new graphics cards as i like the colors
If you are installing the Skyrim HD 2K textures, don't bother installing Beth's High res textures as I found the cause of the stuttering. Skyrim HD overwrites beths work anyway and I was running that and beth's high res texture ESP. Pointless!
EDIT : I just uninstalled the texture pack and it uninstalled Skyrim aswell, W T F. So if you have it installed already don't do that, just untick the ESP files or don't install it in the first place :mad: Phew! Thankfully I always keep a back up :D
- FIXED MOD LIST IN OP -
Wish I knew about this before by NOT installing the beth high res texture dlc, Skyrim is SO SO much smoother now and I can use Grass on steriods just fine. But thanks to Skyrim HD 2k textures it looks beautiful, way beyond anything beth has done.
Low end systems can use Skyrim HD 2k Lite :D
No idea what I've done to make it look like this, something's broken somewhere. Does anyone else think it looks a little cel shaded in it's broken state?
