- 14 Feb 2011
3.0.0 Beta 17 is what I'm running.
Also the same drivers by the looks of it.
No joy!
What I've done is make a copy of the Afterburner short cut from desktop. Right clicked properties from the short cut. Applied this in the target box. So it reads "C:\Program Files (x86)\MSI Afterburner\MSIAfterburner.exe" /wi4,30,8d,18
Still reading +100 rather than +150 in Afterburner. Something I'm missing?
Try this:Just tried it and AB still showing as 100mV
Once it works does it ask you for a reboot?
You should have two icons by the way. One is the default for running/opening MSI AB, whereas the other is a new shortcut that you created, which you edit the target path.Still no go.
Is this how it needs to read exactly in the target box "C:\Program Files (x86)\MSI Afterburner\MSIAfterburner.exe" /wi4,30,8d,18 ?
Just copied and pasted from the original on desktop.
Make sure you didn't drag the actual application onto the desktop (I did that myself, and had to put it back into the folderIt's worth a shot.
Just tried creating a short cut directly from the exe in the AB folder but no longer got the option to edit the Target path. The only way was to send to desktop then, edit the Target path but then i'm back to square one, still stuck at 100mV tops. So dunno!
). Use right-click to drag the exe from the folder onto the desktop, and there should be an option of "create shortcut".^
Use VBE7 bios editor.
