Beta 6 drivers arent any better than Beta 9.
By any chance havd you tried the original beta 3 drivers yet? Might go back and try these if you havnt
Good work on the guide Ranger.![]()
Knowing that you made an awesome guide i am very happy that you complimented my guide! Could be better though, got some grammatical errors and im not very detailed in some areas. Please call me out on it if you see anything unclear.
I have not tried this yet.
Don't worry about it. I find the more people reply and use it you get more feedback and can change things to make it easier for others next time. Good work.
Its not working for me.I cant add that after MSIAB.exe its says the file is invalid.
put it after the quotation marks, so the shortcut should look like:
"\MSI Afterburner\MSIAfterburner.exe" /wi4,30,8d,xx
Just replace the xx with whatever you wanted to try.
Ohhh god i feel soo stupid. Thanks mate for pointing out,sadly tho once i altered the voltage and oc'd i got the black sreen problem.
I dont think 60hz is a solution the the blackscreen im already playing 60hz
Im at 60hz and only added 10,still blacksreen at the end of the TR bench.Right after the load drops from 100%.but the way its same as yours Ranger,like i unplugged the DVI connector.It has to be driver related tho.
