Here we go, Build basically complete
As I said earlier, I run into some serious issues using both a 360 and 240 Radiators, but solved it by having the inlets of the 360 at the bottom and putting the fans at the front, replacing the dust filter. The only downside of this is that I can't use the right side hot swap drive bay for a full sized drive, although a lap top drive will fit fine.
Anyway here we go with some pictures:
Really happy with the build. There are a few things to do:
- Change the top rad screws from chrome to black
- Tidy the wiring in the back (there is a reason I did not include a photo
- Get some nice red fan guards or rad guard to make the inside of the rads look better
- Get a better rear fan
I decided to install my Ivy bridge setup first of all so I and compare temps to my previous case (Fractal Arc Midi). It will not take much work to swap for my 4770K later.
temps are well down on before, even with the fans on silent. The graphics cards idle in the mid 20's and under benchmarking seem to be about 42c, they were in the 70's on air.
So in summary...
This case is not quite as easy as I thought it would be, but after some hard thought and graft, I'm really pleased with the result. My temps are much lower and the case is quieter.
I'm not looking forward to using the Blu-Ray drive in its sideways position.
