 - 25 Apr 2010
 - Ipswich
How the **** do you take the front panel off on this thing O_O
You should have seen the amount of stuff that came im too tired to continue this evening lol.
Check my build log guys.
Andy, are all your fans alpengohn's and what sizes did you use? Just found the red clover models on ocuk. They look ideal for what im planning. Ive used the blue ones as replacements for the stock k2 cooler fans. Still undecided though in wether to pick the black or silver/gunmetal version of the 540.
Andy what led light is that on your case? and is it only green or can you choose others?
Also can anyone recommend a decent fan controller?
NZXT Hue mate, £40 odd, changes all colours
http://www.overclockers.co.uk/showproduct.php?prodid=CA-115-NX
Not sure on fan controller, haven't had one in a while.
Are Alpenföhn fans better than Corsair ones?
I haven't used corsair fans myself. But i have a few alpenfohns here. Was very impressed with their cooling ability. Theyre also of incredibly good quality, the frames covered with a layer of rubber. Noise at full speed isn't very loud either.
