Training with a belt is less about requiring the belt to train and more about being comfortable with the belt. You dont just want to throw it on when your at your limit at a meet.
I am happy to do unbelted training but with a long term goal of giong to meets I need to be comfortable in a belt while lifting, this will only come with extra practice. Also making sure that form is not impacted by the wearing of a belt is also important. Its pointless to put the belt on to gain an extra few KG if the belt pulls your form out - or more likely in my case highlights issues that are less easily seen sans belt.
There is also the argument that you can push your core harder with a belt as well so your actually training harder with one on but thats a whole other discussion.
The focus for my unbelted training has been to improve my core strength which i have been doing, but i also know that with wearing a belt i can maintain form, brace more effectively and add kg's to the lift due to this improved bracing.
I was never saying that a belt is a prerequisite to powerlifting, "a belt is a posative advantage for competing in powerlifting and is not something that should be thrown on just before max efforts" is probably a better way of putting it.
Far from starting from a faulty presumption.
Completely disagree.I think you're starting from a faulty presumption: that you NEED a belt to be a powerlifter.
You don't.
They might help a lifter push that much harder once your form starts to break, but the question is: do you really want to push past the limit of your body's ability to brace?
If you're competing with lifts where you know your going to compromise your bracing at some point in either a deadlift or squat, then a belt can help maintain a degree of thoracic pressure over unbelted. But that is way up the intensity scale to where you should be training on a day-in, day-out basis. IMHO.
Phaggot oly lifter.
Please elaborate.
Or does phaggot cover it?![]()
I been going gym for 3 months now 3-4 times a week doing 3x8-10 mainly except on squats/benchpress i do 3x6 but i am having an issue which i can't understand why so thought i would ask here.
Every few weeks my lifting amount on each exercise is increasing a steady stable rate but when it comes to benchpress the amount is going up very slowly....yet i am lifting fairly well on arm/chest/shoulder exercises and my technique seems to be good for it.
So:
1.Would it be best for me to do maybe weight increases on each set for benchpress? or is there some other exercises which will help me improve for it?
2.My left arm is fairly weaker than right due to my broken fingers so my grip isn't as good yet it's improved a fair amount i guess using dumbells for a few months will help a great deal?
I know those feels.He's strong generally. Apart from when he hits his cawk cleaning.
i've found an awesome new way to loose weight, be unable to eat due to multiple mouth ulcers!
i;ve lost a stone i na week so far, and ive never been more hungry, i keep looking at the fridge full of Christmas goodies and thinking "soooon"
Try stomach aids. I've lost 2.5 stone in 3 months and that isn't water weight like yours will probably bei've found an awesome new way to loose weight, be unable to eat due to multiple mouth ulcers!
You've just made me appreciate the fact I haven't had any for at least two month.. I used to get at least once a month so very good for me aha! At least if you have only one you can eat tilting your head to one side and just about manage![]()
"If your goal is to get stronger (and you have been lifting longer than two months) and you refuse to wear a belt, you are a ******* idiot."
Now I'm not sure whether to start using a belt
Not sure if srs.
