caved in, will give it a go when im uh....not under the influence
Just caved in before too
Will give it a go when the speed of Three's tethering allows
I'm hooked too. I'm using a 360 controller but may invest in a wheel now...
I've found that the best way to learn a track is to start in the Abarth, move onto a BMW M3 E30, and then the Pagani Zonda.
If you want a sense of speed (as well as danger!) try driving the 1960's Monza track in the Zonda. Minimal crash barriers and trees next to the track!
What are your settings for the xbox controller?
I'm actually using a 'MadCatz GamePad' which I think is an officially sanctioned clone.
The settings I'm using are:
Steering Speed - 30%
Gamma - 3.8
Filter - 0.7
Speed Sensitivity - 0.1
Dead Zone 0.3
Rumble Effects 10%
I also swapped the gear shift keys over between X and A as it felt more natural.
But I'm no expert in driving games or using a gamepad. I'm not even sure what 'Gamma' and 'Filter' actually do.
Like you I'm still searching for the best settings, but I'm just getting a feel for the game before I start fiddling around with the controls.
Cheers Borsch! wasn't even aware they had a site tbh. Should I save for the G27 or keep the Drift OZ? G27 seems a LOT smoother to turn etc, plus the additional clutch pedal.
Oh dear, this is going to cost me a fortune. My G25 shifter is playing up so I've just pre-ordered the Fanatec ClubSport Sequential/Gated shifter.
