Scoreboard updated.![]()
@Matt, not as much over a 7990 as I would expect. 20% over an oc'd one?
Got a slightly better score Kaap.
Kaap even with a higher fan speed i still noticed the score dropping off a bit on the second run. Nothing huge but 10-13 points lower.
The above is quite normal and probably nothing to do with your cards, as the rest of the PC gets warmed up it becomes less efficient which reduces the score slightly. If you are really going for it, the best way to do it is to work out in advance what settings to use, turn on PC from cold and go for it.
Is this normal fps drop?
Yes thats about the size of it mate. 7990 is a top card and has very mature drivers so that stands in its favour vs immature 290 drivers. In fps terms with both setups at stock, the 290 setup is around 15-30fps faster than my 7990, depending on the game/bench. This is just guesswork on my part from keeping an eye on the fps counter. It might be more/less.
Yeah I suppose the drivers will get better over time. How are you finding the new setup?
My original plan was to get 290 Crossfire so I'm curious.
