- 9 Oct 2009
- United Kingdom
Very nice shots. Is that fsx or P3D v2?
However it says that FTX global is a requirement for vector in the first place so having the discount seems a bit pointless to me![]()
"GET 10% OFF IF YOU PURCHASE FTX GLOBAL BASE BEFORE THE END OF DECEMBER!"
So for the 10% off you need to get Global pretty soon, also remember most of their stuff is also in a sale for a couple more days
Wondering if anyone had upgraded from REX 3 to 4. Is it worth the upgrade? Are the textures provided much better?
Shame all they offer is $5 off to existing REX owners.
fantastic shots!!
I now have both, and am keeping REX3 (essentials) along side REX4 as it has textures I like, and the ability to custom colour water, which v4 does not have. TBH I don't think REX4 offers a great deal for current REX FSX only users.. some of the new water animations are nice, as are some of the new textures, but how many textures do you need? the integration between FSX and P3Dv1.4 and v2 is very good however, enabling a simple bullet/tick to place the textures in the sim of your choice, if you're running multiple installs... and the textures and animations have optimisations for DX9, 10 and 11.
Also note, this is JUST textures, and you will need to add other REX sections, when released, to get the weather engine and flight planner... or use 3rd party products.
Thank you![]()
what would be a good medium spec pc for fsx?
I have been using the new Active Sky Next for the last few days on a trial which runs out in 2 days, its fantastic well worth a try if anyone is looking for a wx add on
So, I treated myself to a lot of stuff over Christmas so I will be re-installing my FSX again. Can someone have a look at this and make sure I'm not doing anything daft?, and any suggestions on which order to install this stuff? This is a checklist I came up with (in the spirit of flying)
Install FSX Vanilla - Run & Activate, close.
Install Acceleration - Run& Close.
Install PMDG 737 & 777 & any other aircraft
Install FS Global 2010 (This will take days, took long enough to d/l)
Install ORBX FTX Global + Patches
Install ORBX EU Eng + Scot
Install FTX Vector
Install latest ORBX libs
Install UK2000 airports
Install REX OD+Ess + SP's, install textures @ disable Wx
Install OpusFSX
Run O&O Defrag in Complete/Name on D Drive (FSX @ General Storage Drive).
Tweak FSX (widscreen=true, affinitymask, stick_sensitivity_mode, general graphical options)
Profit?
Seems like a lot to do to get FSX working when I spell it out like that. I think once I have done this once I will make an image of it so I don't need to do it again.
At the moment, my spec is i5 4670K, GTX770, 8gb ram. Does the job, keeps a fairly solid 30fps at 5760x1080 res with a ton of eye candy, and doesn't really break the bank.
