I'm going to pop my PI on the mm in next few days mate. Can give you first refusal when I post up (I know I can't sell outside mm but a heads up as we dealt with in there before).
Top man!
Intel® NUC Kit D54250WYKH is the one I want, not sure it's out yet though?
I presumed it was a driver issue?
It's only an issue if your amp is earthed. Basically you get a constant buzzing issue as the PSU for the AMP and NUC fight to balance themselves (I'm no expert) but the buzz was driving me crazy. Tried same socket etc.. the final fix was to buy a double insulated psu, these don't need an earth. Not too expensive £16 for 65w 19v laptop PSU (no earth is ofc 2 pins into block instead of 3).
Anyone know if its worth upgrading to v13 gotham beta's yet or is everyone staying on v12 for now?
I have one of these, but not for XBMC, I run mediaportal on it. Initial thoughts are
It is tiny
It is very very tiny
I have the i5, so there is a fan, but I haven't really noticed any noise.
It is really quick, menus in MP really fly with the HD5000 gfx
Sound is a major major issue, Im running using my tv speakers over HDMI as my other speakers are unusable, I have just seen for the first time now the comment on noise and earth, I need to go off and research this as this is the first I have heard, I presumed it was a driver issue?
The whole box has a real quality feel to it
Right now I have the new server and backup server in place I want to do this PITA my sql so libraies sync around the house.
Are there any issues with domains?
I have added the backup server to the domain controller server and and created a user called XBMC in server 2012 with read access to all the media folders on the server.
The xbmc install will be on the Backup server running windows 8.1 with the actual media on the Domain controller server. Both are on 24/7
Are there any issues with running my sql and XBMC on a domain? And I take it the sql database does not need to run on the PC with the media on? I do not want to install XBMC on the domain controller running server 2012 R2 in the out house.
I want to install XBMC on the backup server in the study running windows 8.1 as this PC will replace my HTPC under the TV being used currently.
I've just updated my XBMC to 12.3, but rather than the official release, I've just installed the Margro prebuild, which incorporates a few tweaks, most notably faster channel switching with LiveTV with ArgusTV as the backend.
Tuning the first channel still takes a few seconds, but subsequent channel changes are now almost instantaneous, rather than taking ~6 seconds, which would make it much better for anyone wanting to channel surf LiveTV (it's now quicker than the last time I used a Sky box!)
(I still think that anyone watching Live TV and channel surfing is using XBMC incorrectly... but that's just my opinion!)
It's usually someone saying "oh, did you see X" that will prompt me to set up a series link anyway, rather than watching an advert or browsing the EPG.Has anyone setup ambient LED lighting around their TV for xbmc? I quite like the idea but the options seem rather expensive for pre built kits. I'm moving soon and the TV might end up in a corner which wouldn't work, but if I do manage to get it flat against a wall I'd like to setup some ambient lighting for movies.
