It seems Excavator will happen and it is DDR3/DDR4 compatible too.
This was posted on SA forums:
http://www.gdm.or.jp/voices/2013/1230/56219
The CB R15 score is around 4GHZ to 4.2GHZ Trinity level(the Kaveri CPU is running at around 3.7GHZ).
5% or so, meh... not even worth bothering with.
Wow... hang on. wPrime, Sandra and Supper PI are Floating Point performance, its what AMD have always been weak at. (Gaming)
Are those slides telling me Floating Point performance is up 25% clock for clock? its impressive if it is, and much much more acceptable performance full stop.
CineBench is integer performance, thats up a solid 10%, not bad. not bad at all.
I believe I talked about this optimism in 2012
Also, I think you have it the other way round, Cinebench is Floating point as far as I'm aware.
"PD's clock for clock 25% better than Bulldozer"
