Nvm, you're obviously tired.
I don't understand what your talking about, i said according to those slides the FP performance is up 25%, and that its impressive if true.
I think you miss-read my post. again?
I didn't mis-read your post, you're not understanding what I'm saying.
Nvm, it doesn't matter.
No, I didn't.
Back in 2012 when the Trinity previews came about, you saw a result, and the next minute you were claiming 25% improvements clock for clock.
You said literally the same thing just there, so I made a tongue in cheek comment.
End of.
So far Kaveri looks like it could be very nice indeed..
http://www.anandtech.com/show/7507/amd-kaveri-apu-launch-details-desktop-january-14thAMD has confirmed that Kaveri will be shipping in Q4’13, with a launch/availability date of January 14th, 2014.
The 7800 is a (65w) part, this could mean that the GPU does not clock as high, if the APU has some sort of turbo and (720mhz) is base clock. If that is the case with the (65w) beating the 6800K slightly in GPU performance, it could mean the top part 7850K might have a significant advantage over the 6800K in GPU performance as well as CPU performance.
Looking forward to legit reviews.
I haven't played with richland or trinity, obviously not even Kaveri, But you sure that they will not overclock at all with a locked multi.
I maybe wrong but thought you can clock them using ht ref like the old athlon x2/x4 on the am2+/am3. Just you have to play with the multi for the ram divider and the nb, also limited by the max multi of the particular cpu and the ht ref will be capped to about 136 ish due to the igp being pushed too?
My 4.375GHZ 1055T was all bus clocking, the 1055T being a locked CPU.
