AMD Launches Three Kaveri APU SKUs in February 2014 – Feature Set For A10 and A8 APUs Detailed
You couldn't raise the multi's, only lower, that's not unusual, you know given it'd been going on for years :p?
As i said, the last locked AMD CPU i had was an Athlon x2, i think that was back in 2007, all the Black Editions came right after that and i jumped on them.
Or the 28nm process is a pooper and you'll hit a brick wall at 4.1 ghz ;)
Ooh sorry i'm so negative with Amd these days, must be too many years of disapointments.
The GF 28NM process is bulk as opposed to the 32NM SOI process they are using now. Density will of course go up,but OTH I am getting the impression clockspeeds have not. AMD really cannot do much ATM about it as they are too small a company to own their own fab and develop process nodes which keep up with Intel,and even though GF has the second best large volume node for big core CPUs it is quite behind what Intel has. IBM themselves are using a 22NM SOI process for their POWER chips,but I get the impression it is quite expensive and small volume.
Edit!!
You can see the 28NM node probably has issues as the AMD performance estimates were higher when leaked months ago. The node has had big delays and GF only started producing small ARM based SOCs on it last year. I suspect,like with Llano,Kaveri has missed its clockspeed targets. That is three out of the last four process nodes GF has had problems with it seems.
Edit!!
GF have been a never end source of AMD delays and problems, for years now, there must be better foundries out there that AMD could use.
In anycase i don't think overclocking these CPU's can be any worse than Haswell.
We will find out soon enough.
Edit!!
Like you say Amd need their own foundry again, but thats never going to happen. Gf have hampered the progress of Amd recently. Krishna and Witchita should have been on 28nm-SHP, Richland should have been on 28nm but at the time gf had issues with their 28nm. It seems they were stuck in between tsmc which provided 28nm but at low clock speeds hence Temash and kabini were low clocked and entered into the markets accordingly, or to respin on the long in the tooth 32nm. It is my belief and opinion that as they were stuck on the 32nm, Richland could have offered a gcn derived gpu if Amd had been on a 28nm process. Thus Kaveri would have then been a stronger performing product than it is now,, But then again they haven't addressed the memory bandwidth issues even now.
Still I will be buying Kaveri to have a play with in itx size.
Ibm 22nm has two problems low yield products and a high price. But as you know it would be useless for Amd that targets the oem sector and needs a high yield low cost production.
I'm not hugely clued up on the fab work, but how did Amd manage to transpose lithiography from the 28 tsmc process of their gcn pitcairn into the gf 28nm process.
Edit: I wonder if the clocks are reduced due to instability/brick wall or to reduce the power consumption of the soc. These are things that can be assessed when they make it to shelves I suppose. Also a concern is that they havent hinted at the mobile kaveri platform at all, unless they are being very quiet, i'm worried that maybe the tdp/prformance won't scale well in a notebook format, compared to richland maybe?
Edit!!
I hear IBM only need 1 solid sale (read mainframe) to make a whole wafer profitable. OTOH even Intel will begin to feel the pinch, with a somewhat floundering market and increasing difficulty to fab at smaller nodes. If, and it's a big if, AMD can hold on til 2017-2020, I reckon we could see process parity. Hopefully X86 is long dead in the mainstream by then, and we can see what both camps can produce without all this IP license bull
Your original link was the game chart and I read it as you saying it was mantle performance :p
I'ma take the charts with a grain of salt, because Mantle's doing over 300% there as it's FPS when it's just the Kaveri.
Kaveri review by some shady source..
http://tieba.baidu.com/p/2795083406
Google translate..
Just found an old wPrime result whilst cleaning out my PhotoBucket account.
Phenom II x6 1090T: 6.084 Sec @ 4.2Ghz
There is however a huge discrepancy between 1.55 and what they used which is 2.10.
I like the cryptocurrency mining features that AMD are 'showcasing'. Perhaps it could form a low cost starter PC for coin mining without breaking the bank & add GC's later on??
Hmmm.... I have an A88X board.
Do I stick a low-profile 7750 in for £80, or get the equivalent Kaveri after selling my 6400k?
