It always gives that warning and WhyScotty has confirmed it is the same BIOS he uses Alex![]()
Sweet, cheers Greg. Flashing time!
No probs. I have to go to work soon but if you run into any issues or get stuck with anything, lemme know. We are not that busy on nights.
I flashed the skynet 780 classi bios without any issues but when I try to enable to MSI AB hack for 1.3V, both the 3:20h and 4:20h lines return an invalid result. Does this mean my card can't be overvolted?
You don't use the hack on the Classys
Thanks Neil.
I supplied the Classy voltage tool in the OP
Is that all that is needed Neil?
Thanks Greg and scotty. So I just need to use Zawarudo's tool?
Edit - I am using the AB version in the 780 folder on your skydrive Greg.
Not sure Alex and think you will need the Classy voltage tool to raise volts but I expect the Zawarudo tool won't work.....
Neil will confirm.
Ah ok thanks Greg. I just tried Zawarudo's tool. It didn't raise voltage but no crashes either. Will see what the classy voltage tool does although it isn't as pretty or as intuitive as the former tool.
Classy tool does the job
 just need EVGA to release a biosAwesome post thx Greg I've been looking for a guide like thisjust need EVGA to release a bios
