How to over volt a Titan, a 780Ti or a 780 guide
I flashed the skynet 780 classi bios without any issues but when I try to enable to MSI AB hack for 1.3V, both the 3:20h and 4:20h lines return an invalid result. Does this mean my card can't be overvolted?
Thanks Greg and scotty. So I just need to use Zawarudo's tool?
Edit - I am using the AB version in the 780 folder on your skydrive Greg.
Not sure Alex and think you will need the Classy voltage tool to raise volts but I expect the Zawarudo tool won't work.....
Neil will confirm.
Neil will confirm.
Ah ok thanks Greg. I just tried Zawarudo's tool. It didn't raise voltage but no crashes either. Will see what the classy voltage tool does although it isn't as pretty or as intuitive as the former tool.
Classy tool does the job
Scotty I just tried the Classy tool. I had AB running at the same time with the voltage on that unlocked and on +62 (max it goes). Also had the classy voltage tool open and unticked auto. Put the slider to 1.25V and ran a bench but the max voltage it shows on AB is still 1.212V.
Am I doing something wrong?
