Asus Realbench 2.0
Set all to above but when running the bench i get a message "program files modified or corrupt" showing in the bench score section, followed by a 0x1A bsod.
1A = memory management, if your temps allow up sa, io to 1.25v if not drop the speed down. Can you go 2600mhz??
That was at 2600, temps were maxing at 67c iirc. It completed the first two tests before the error then blue screened.
Managed a complete run at 2600mhz, upping sa/io seems to have helped. But cache seems to have dropped going by cpuz.
Heres one to try if your on 45x multi
Leave all volts (including dram, could turn down to 1.7v for this) as they are, set your timings back to xmp and speed back to 2400, now change your multi to 44x with a 102.3 Bclk, see what that gives you.
Ill give that a blast tomorrow mate. Just ran it now, (2 passes) 2600mhz ram, 43x cache, 1.25 on io/sa. Completed the first pass with a score of 82458 but blue screened on the second run. 0x124 which can be vcore or io/sa iirc.
84f29a0c-739e-4c5c-b43d-3cec1f39c185_zpsde6d2be7.png~original
Specs as per sig.
#1 101298 Nickolp1974-Intel I7 [email protected]
#2 96782 Stulid-Intel-I7 [email protected]
#3 84413 Wazza300-Intel-I7 [email protected]
#4 83649 Amigafan2003-Intel-I7 [email protected]
#5 82342 Setter-Intel-I7 [email protected]
#6 81478 1Deep-Intel-I7 [email protected]
#7 75311 OLDPHART-Intel-I7 [email protected]
#8 70200 ALXAndy-AMD FX-8320 @4937.2mhz
#9 69182 Dempsey-Intel-I7 [email protected]
#10 63796 Famas-AMD FX-8320 @4615.4mhz
#11 62897 Krony-Intel-I7 [email protected]
#12 448 humbug-Intel-I7 [email protected]
I'm new to all of this but would having a GPU make any difference to the score or is it strictly CPU? As you can see from my screenshot Im running on integrated graphics until I decide what card to get. Also the RAM timings, should I go about tweaking them with the variable guides ?
4670k @ 4.4Ghz , Max temp 57c
