Caporegime
- 18 Sep 2009
- Dormanstown.
It was the original b2 revision, as b3 was announced a week after launch which removed it.
I'm holding out a lot of hope for Kaveri, we've seen plenty useless rubbish AMD reviews posted before..
I'm sure I'll be as disappointed as everyone else come launch day.
Not as impressed as I hoped I would be with those GPU scores.
I have a GTS 250 which I recently ran the SFIV bench with and got around 85fps (will have to check the AA settings, res was a little lower at 1280x1024).
Recently moved to AM3+ from an ancient rig, and had been wondering if I'd backed the wrong horse - but Kaveri isn't quite as mind blowing as I'd been imagining.
Much disappoint.
Such mediocre.
Was planning on building a Kaveri based small form factor PC this month, looks like it will have to be a Haswell dual core instead![]()
Much disappoint.
Such mediocre.
Once you try that Haswell dual core that frown will turn upside down![]()
No way a locked 2 core chip is better than an unlocked 4 core, you can get the AMD unlocked 4 core to match the locked 2 core Intel in single threaded performance and destroy it in multithreaded performance, plus you get a vastly better iGPU to boot.
Even the the unlocked 4 core Athlon without the iGPU cost nearly half as much as the i3 while doing the same as i described.
Sorry but they don't, especially not in FPU performance.
Yes they do.
The FX8320 sorry but no hinting and with a Gigabyte GA-970A-UD3P or Asus M5A97 Evo R2.0 for around £70 should make a nice little setup. OTH,an FX6300 and a Cooler Master Hyper 212 EVO would cost around the same.
Indeed, some i3's are more expensive, Intel are out of touch.
Bit annoying your post was edited Cat, OCUK had the FX8320 at the price you mentioned just the other day.
