- 17 Nov 2005
- Swindon, UK
I love it, but it depends what you want out of it. What are you looking for in a sim?
Brian, we still need to go through the Airbus. Let me know when you available and we can do it.
Anybody managed to get a password for the Electronic Flight Assistant account? Been waiting a good 4 days now.
Copied from my thread in peripherals in case anyone here has any ideas!
Basically my joystick is fine when I check the calibration settings but as soon as I get into game the z-rotation (rudder) axis only works half way when turning it to the right - left is fine. It's the same in all the games I have, FSX, Cliffs of Dover and War Thunder
I read that it's fairly common for a connector/wire to come loose inside so i took it to bits but everything looks ok. The fact it's fine when I initially plug it in makes me think it's a driver issue, tried reinstalling driver multiple times but the problem remains...
I should add it's a Saitek Cyborg X, also sold as F.L.Y 5 I believe.
I bought the 777 last night! haven't installed it yet as I want to have a good go at it when I have plenty of time.
If you are up for a check ride at the weekend in then let me knowalso when we flew last you mentioned that a new version of either pfpx or efb was coming out, which was it? I cant remember what you said!
The performance calculator for the Q400 that I mentioned is here :
http://www.aurasim.com/
its free you just need to sign up, doesn't seem to take into account Anti Icing so remember to add 20kt if you are in ice![]()
