- 27 Jan 2014
You can fit a 780Ti easily.
Brilliant, that's all I needed to hear, thank you
I shall order one shortly ^_^
Hey guys,
Been out of the game for a long while and have been contemplating getting back in with a new build using this case. If any of you care to take couple of measurements for me, that would be great
*Is there enough clearance to fit a 420mm radiator to the top of the case?
*If so, and if anyone has done it, how much clearance is there between the front of the radiator to where it meets the bezel?
*Likewise I see some people have fitted 360mm radiators to the top of their rig, can you tell me how much clearance there is between the front of the radiator to the front bezel?
Reason why i ask, is i want to see if there is enough room (even if it will be a tight fit) to fit a fan controller (Bitfenix/Lamptron haven't decided yet) to the top.
*How much clearance is there measuring from the top of the motherboard to the top of the case... as with above, i want to see if the case has enough room to fit a radiator in push/pull configuration (ignore the exhaust fan at the back).
Lastly...
* I plan on anodising the case, is the front facia all plastic or aluminium?
Painting my 750 blue at the minute![]()
I will stealth those cathode cable's at some point today too, just wrap them with some black electrical tape to hide them. res/pump combo appears to be doing a decent job, 4770k at idle is 19 degrees, under prime gets to about 50+ at stock speeds, will overclock to 4.2 most likely and leave at that, happy now
