I think i might know what causing my yawing issue, as i increase the throttle 3 blade spin up with the forth to follow, also that one of the motor has a slight resistance when you turn it. Cant do anymore testing yet its just started to rain
 it's the same regardless of the wind.How many satellites do you have locked? If you only have the minimum required for a position lock the GPS may still only have a resolution of 5-10 metres. Most people recommend hanging around for a few minutes until it has aquired more satellites.If I fly our Phantom straight away from me, say 100m, and then straight back again, it finishes about 5-10m to my right. What could be causing this and what do I need to do to rectify it?
DJI love to use crappy screws. I managed to strip one of the motor mount screws on my S800 EVO. That was a pain in the backside.
 Doing some troubleshooting on it and chatting in the RCGroups thread but I'm not going to be keeping it like it is at the mo.Took a dremel cutting wheel to the head yesterday, when it (still on its spindle) worked loose at full speed. I was wearing goggles at the time but it was a sharp reminder and will definitely make me think twice if tempted to cut something, however insignificant, without safely goggles!
