I came across a few of these batteries, are they any good for a Hubsan x4 etc?
http://s74.photobucket.com/user/spanker_photos/media/photo1_zpsbed828a8.jpg.html
Guess so in theory, think the 808 is a single cell lipo the same as the X4. Realistically you aren't going to find a camera that is bothlight enough for the X4 and has decent quality without spending a lot of cash.
Better to go to a bigger quad and know you can just add an 808 or a Mobius easily![]()
What disc were you using and what was you cutting ?
So it weights about the same as the airwaves.
Is it possible to take the 808 out the case and power both the x4 and camera from the same battery? This would massively reduce the weight of the camera I think
). The new setup wizard in Mission Planner walks you through the setup for you now which is handy, you'd need to be a bufoon to struggle now
Bagged myself a Phantom 2 last week, so just like anyone else would do, I immediately tore it to pieces to mod it.
Fitted H3-2D, FrSky X8R rx, iOSD Mini, 3-channel video switch, fixed camera, 250mW vTx.
Very nice setup, almost exactly what I plan to buy for summer.
Have you flown it yet ?, if so would love to know how long flight time is.
Why not just get the HD camera version of the X4 that has the 1280*720 camera?
It's more powerful than the standard x4 as it has bigger motors at 8.5mm Ø vs 7mm Ø.
I did think about it and has positives and negatives
pos
Its only £50
I could sell my x4 and recoup some of the cost, I would imagine around £30-£40 with prop guard, 4 additional genuine batteries and prop removal tool
neg
prop guard and 4 additional hubsan batteries will not fit
camera quality is only apparently on par with and 808#9 (but not #16)
