- 7 May 2006
To answer your question about how its passing through the walls it might not be passing thought the walls. although it could be at a guess the most likely places would be at the bottom of the walls or below you're floor boards and in the ceilings.
It could be that you have some nasty internal cracks/opens in the walls within and the smoke isn't passing through but seeping in.
What type of house do you live in? does it have shared floor boards or supporting beams that pass through the house?
The smoke could be going though the floor and in to the other house.
The smoke could be going in to the celling and traveling into the roof and back down again.
Windows how close are they to each other and are there any chance it could be travelling from the windows, gaps around them etc.
Do you have any noticeable draft in the house?
Thing is it could be any number of things and you could look to try and stop it but the effort that could be involved to do that wouldn't be worth just not smoking in that room.
