- 18 Mar 2010
Try:
Settings / my device / home screen mode / select standard mode not easy mode
That worked, thanks. I am sure I had easy mode with multi screen before though?
Try:
Try:
can anyone suggest a replacement charging cable? I have had both the official samsung ones that came with the phone fail. Wouldn't mind something longer.
Can I just get any usb-micro usb cable?
I thought that the old samsung galaxy s2 was also called "micro-usb" but is a different size to the one used in the note 2. what is the correct name to describe the note 2 version, how are they differentiated?
Can someone point me in the direction of a comprehensive guide to installing a custom ROM?
After upgrading to 4.3 my battery is shocking and so is my signal, I'm hoping to find a replacement ROM that wasn't put together by monkeys!
Try doing a factory reset. When I updated to 4.3 my battery life was appalling. After a factory reset it is better than on 4.2.
