AMD Mantle Vs. Direct X Battlefield 4 Multiplayer Benchmarks
Caporegime
12 Jul 2007
United Kingdom
28% improvement at 1440P with a 6 core cpu. Expect bigger improvements with a lesser cpu.
You might recall I have been ranting on and on about how Mantle will work wonders on Multiplayer gaming because the situation is so CPU bound. Well, I have finally gotten my hands on standardized Battlefield 4 Multiplayer Benchmarks with Mantle. Since Multiplayer is an extremely tricky thing to benchmark because the conditions change with every run, these benches are quite unique.
AMD Mantle Vs Direct X Multiplayer
AMD Mantle Vs Direct X Multiplayer Crossfire
AMD Mantle Vs Direct X Crossfire
Source
http://wccftech.com/amd-mantle-direct-battlefield-4-multiplayer-benchmarks/
Caporegime
OP
12 Jul 2007
United Kingdom
5 Sep 2011
Surrey
Yeah there are way too many threads on this now, when you consider it's one game lol. I linked it in the BF4 benchmark thread an hour ago :D
Slightly annoying how they've skipped 1440p :(
28 May 2007
Make it clear in the OP that the percentage you're stating is for CF then :).
8% on single card is a bit meh IMO. Need to see what it's like when it's been implemented from the off as opposed to patched in.
Higher frame rates and extra smoothness is not to be sniffed at tbh.
Have dice patched the extra fogging out in the recent patch?
28 May 2007
You won't notice 8%. It's not high enough a percentage. 25%+ on CF isn't to be sniffed at though, you're right there.
Mantle is smoother than dx on it's own without the extra fps according to those that have it running properly. Yea crossfire needs more cpu power and it could be the case that the more cards you add the more gains you get.
