14.1 lowered my performance in all DirectX games (My Fifa went from 500 FPS to struggling to break 200).
Had to do a reinstall of windows for it to fix.
Why not just use DDU?
You're still attacking the straw man as you're arguing along the lines that I'm saying there's no improvement between AMD DX and AMD Mantle which I'm not. Dunno what else to say really.
What a relief.
Take look at this Ultra footage I recorded with Mantle. Note how smooth the GPU and CPU line is. Now you go and do the same recording on same map with DirectX and you watch your line will be all over the place. With higher Frame times.
FreeSync will be a while yet, and as someone here who dont touch sync I have zero need for it![]()
Why not just use DDU?![]()
No im saying that Mantle and a 290 will offer a smoother experience in rendering times than a 780 on DX.
14.1 lowered my performance in all DirectX games that I was playing at the time (My Fifa went from 500 FPS to struggling to break 200, and it wasn't as smooth either, little stutters etc).
And I just installed AMD Drivers like I always do.
Had to do a reinstall of windows for it to fix, on 13.12 everything's fine, flawless in fact.
Mantle may be great, but I'm not going to ruin all my other games for it.
What a relief.
OK - have you compared? Or got a link?
Not looking at frametimes because they're already low enough (and evidently consistent enough) to not really be noticeably improved upon?
Nothing wrong with other games here. User error dont mean everyone will have same experience
But I can say Benchmark's like Heaven 4.0 and 3Dmark run much worst.
How can it be user error if I'm simply using AMD's installer?
I've never said anything to the contrary. This is the problem when you don't read the posts being written
For anyone else: don't confuse that with me not thinking improvements aren't possible or that Mantle isn't doing the right things... I'm just sceptical about what benefits are being provided currently over a similar high end nVidia set up. I think that's largely the problem.
I'm comparing it to the results from various tech sites that say before Mantle AMD have better frame times and less variance than Nvidia in this title on single gpu, like for like. Couple that with the fact that when i tested a single card, i could notice the difference in the smoothness on moving from DX to Mantle. So i can notice it with lower frame times (cpu+gpu) than you, you should be able to feel a smoothness increase with slightly higher frame times (cpu+gpu) if your 780 was able to move from DX to Mantle.
. Could you tell the difference between frame time x and frame time y with 3-5ms difference? I want your eyes if so
.1280x720 Humbug?
Screen cap. its in Windowed mode as i have to use BandiCam to manually overlay a capture window, no other way, or other app that i know of will record / cap Mantle.
The CPU is a P-II x6 @ stock (3.2Ghz) i'm still experimenting before i overclock, but even at stock it does not hinder performance at all.
Long way of saying no then?
I said exluding frame times unless we're splitting hairs over 3-5ms difference. Could you tell the difference between frame time x and frame time y with 3-5ms difference? I want your eyes if so
Then what is this?
Proof was given to you, but you chose to ignore it.![]()
Let's take it one step at a time:
1. You have tests in which AMD is better on frame times (the big nvidia is better argument a while back) under DX and it only gets better under Mantle;
2. You have tests in which Mantle, frame rate wise, can go from 0% improvement to double digits numbers, even on high end setups. The empirical data is all there and it clearly shows under which situations Mantle kicks in and under which is not better. 'cause yeah, no one says it's better all the time. Even AMD said this API isn't required for all type of games. A lot are fine with how DX works.
You can feel the difference Rusty, so yes. If i can feel the difference with lower frame times then you will with higher frame times. You may not want to believe it, but its true. You just don't realise, but then you've only ever known DX so i guess thats why.
It is a very interesting debate with both sides giving valid reasoning to their points. What you put there is just plain rude!
