Star Swarm - Oxide bench thread
Of course there is, you'd be naive to think it's not. It is a Mantle showcase at the end of the day, why on earth would they optimise it properly on DX :D.
Stupid thing is, there is the option already in there to get a better run on nvidia hardware by enabling deferred contexts, bizare that it is off by default, the motion blur effect also kills performance, turning that off i average over 120fps from 35fps with it on
"We'd like to point out that our Direct3D performance is absolutely outstanding, relative to what is expected. We have spent a huge amount of time optimizing around D3D, and we feel we are actually pretty biased in D3D's favor. Mantle, on the other hand, we've spent far less time with and currently have only pretty basic optimizations. But Mantle is such an elegant API that it still dwarfs our D3D performance."
Source
http://www.tomshardware.com/news/oxide-mantle-gpu-directx-star-swarm,26029.html
Full Interview
http://www.maximumpc.com/AMD_Mantle_Interview_2014
Well, if that is the best I can expect it to run on my system, I don't see much point in buying the game. I have no wish to play a game at 12 fps at times :)
Its not a game though is it. Its a benchmark designed to showcase the limitations of D3D and show it for the inefficient API it is when compared to Mantle. :)
I have lost count how many times this has already been explained.
By letting GPUs run at 40% utilisaton in DX? Even Skyrim vsync capped gets higher GPU usage.
Exactly, because its a limitation of D3D. You can even see it in BF3 and 4 sometimes, if you have more than one gpu. ;)
Lol. I know. Prepare a brick wall, i think we might need to bang our heads against it shortly.
Ahhh but if it is incorporated into a game (Of which I am sure the nitrous engine is for), I will be avoiding anything that uses it.
If it is purely a showcase for Mantle vS DX, then it is fixed. AMD paid for it and are showing the results they want you to see ;)
Brick Wall.
Brick Wall.
Lol, im out.
You have absolutely no idea on coding for DX or Mantle Matt/Humbug (as I don't) but feel you know enough to trust that DX is so badly optimised that it can't get my GPU running faster than 40% (when left on default settings) and that is with my CPU at 5Ghz (and that only reaches 30% usage on a couple of cores).... Probably best you are out to save embarrassing yourself.
Never went below 70-80% in BF3. Doubt BF4 would be any difference. That's two GPUs though.
It just sounds like an excuse for bad handywork tbh. Whatever though lol.
40% isn't solely due to DX. You're kidding yourself if you think otherwise. I have no problem with it being to showcase Mantle though but I just don't believe it's a fair representation of what the real world benefits of Mantle are. Because let's be honest if this engine in its current form made it into a game, there'd be uproar if the mass majority of the market couldn't get their GPUs past 40% in DX. Well there probably wouldn't be uproar as people wouldn't buy it :p.
Ever thought it could be the API unable to handle the massive amount of draw calls and other features that starswarm uses?
I want to believe you are right Matt, Ohhh I seriously do but something keeps niggling away at me and I think it is to do with AMD being involved.
Forget it Matt, he already knows all this.
This post here...
Is clearly baiting for exactly the same argument to restart, again.
Yet the makers have said they have spent loads of time on there dx implementation and very little time with mantle. It's been known for a long time that dx has it's limitations. Maybe this and mantle are showing just how bad dx really is.
