Byrons or optifuel would suit best to your usage.
Cheers Hunter. I'm going to order a couple of litres tomorrow.
*edit* Ill try the Optifuel make.
Nevermind, I found one.
*edit* Just found this on YouTube
100+mph![]()
will look nowhere as fast as a car going 100mph though because of how small there are.
my rc did around 50mph but looked like it was only going around 20mph unless you had a car going down the road to compare the speeds
Anyone into RC cars? I just won an auction on a VERY well kitted out Kyosho Mini Inferno 1/16th.
Last car I had was the Kyosho Inferno 7.5 oddly
http://www.ebay.co.uk/itm/Project-R...JogwRYcZwXgFh3cVgLYL4%3D&orig_cvip=true&rt=nc
Looking forward to getting it.
Anyone know how to drop the front suspension on a Traxxas Jato 3.3? Ive looked on Google and cant seem to find anything. A bloke at work says its a couple of screws but I cant seem to see what he is talking about![]()
Just unscrew the screws, move the suspension over to the new holes and put the screws back in.
Try c first as those control the spacing of the pads, only quarter turns though.
I have a Tamiya Monster Beetle. It's not exactly stock.
I'm running a 120a 6T brushless setup, so it shifts a bit. It was a monster, however I've now lowered it for more stability.
