is 2gb not enough?
Of course...
All games 2560x1440, High quality AF forced in CCC and 4xTrSSAA turned on in every game.... It's loverly and produces IQ that pleases my eyes :D
If that result you posted is with just 4xMSAA and everything else maxed, then something is wrong with your system bud.
And here is one with no MSAA
GTX690 @915/1502 stock
Mine with no AA.... Not bad for a £350 single GPU :)
Not really.... it's about right looking at reviews.... I do have TrSSAA enabled on it too :)
I thought you said that TrSSAA wasn't costly in fps. Not that it matters but to me, those frames are very low. 35fps average? I wouldn't consider that playable for me anyway.
Didn't someone Quote a site somewhere that 2gb was not enough for BF4 on ultra settings 4x msaa ect.
As i 670 2gb owner i was very unhappy with the card using 1948 mb of its 2048mb memory on ultra settings and playing very well indeed.
Scaremongering or gullibility on the readers ;)
Generally it doesn't but Hitmans engine is very heavy on the VRAM with AA on.
Just run the benchmark with plain 4xMSAA ( MLAA and TrSSAA turned on in CCC, didn't realize I had MLAA on also. )
Min - 46fps
Avg _ 55fps
I have seen it for years Ian. I remember being told that my 2GB 680 wouldn't have enough VRAM for 1080P because a 7970 was using 2700mb of it. I played it fully maxed at 5760x1080 for months and months with no issues. I had Aero disabled, which freed up a chunk of VRAM but never once did I run out.
Games are more VRAM intensive in some situations though, like FarCry 3 with max MSAA would see me use more than 2GB at 5760x1080 and I am sure that others like Crysis 3/BF4 etc would do the same.
What I am not sure of is what games are coming out in 2014 that people think will start to breach 2GB at 1080P? From what I can see, GTA V will probably (if GTA IV is anything to go by) and possibly The Witcher 3? I am purely guessing though.
I have got a bit carried away.:D
4 stock 290Xs @1000/1250
MSAA X8
1600p
I get almost the same score running X4 or X8 MSAA as I think I am CPU bottlenecked.
IQ looks ****** though with TrSSAA turned off..... If I want to play with ****** IQ I would go and buy a console ;)
Beats Kaaps overclocked 690 results with 4xMSAA with the drivers on default settings.
Well I thought it was about not having enough VRAM and not about who is faster. You also have to compare in game settings, as adding modifications isn't what 99% of people do.
@ Kaap, I am 10fps difference between 8XMSAA and 0XMSAA at 1440P. CPU bottlenecked for sure. I need Mantle :p
I would say the fact his minimums are so **** poor low with MSAA enabled ( And overclocking does nothing for them ) is a nod to the VRAM limit on the 690.
