Where is the first floor?
Status
Not open for further replies.
so if the ground floor is the first floor then surely the basement has to be the ground floor because its in the ground and the first floor is first so then the basement is the sub basement but how can you have a sub basement without a normal basement first?
The ground floor is the ground floor because it's on the ground. A basement is under the ground.
No. Ground floor, lower ground floor, basement, sub-basement.
I have it on good authority that in a secret chocloate factory, they have lifts that go sideways.
No word on the numbering system used, suggest vectors.
It's not zero, this is where the confusion arises. It's the ground floor. The floor on the ground. The first floor is the first floor up. It's very logical. The Mars bar analogy is a bad one because you cannot have no Mars bars. But you can enter on the ground floor.
What number comes between 1 and -1?
What if you have a huge, underground, villainous complex. I really don't have the room for sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-basement on the lift control panel.
lower ground floor :eek:
how many sub basement do you need before you get to the underground lair?
Lower ground is for buildings which may have a level below ground which is not a basement, such as if it backs on to a lower ground outer courtyard.
Basement is below ground, any levels below that are purely sub-basement levels and numbered accordingly, such as -1+.
Status
