Kit Kats don't count ?
so if the ground floor is the first floor then surely the basement has to be the ground floor because its in the ground and the first floor is first so then the basement is the sub basement but how can you have a sub basement without a normal basement first?
No. Ground floor, lower ground floor, basement, sub-basement.
It's not zero, this is where the confusion arises. It's the ground floor. The floor on the ground. The first floor is the first floor up. It's very logical. The Mars bar analogy is a bad one because you cannot have no Mars bars. But you can enter on the ground floor.
lower ground floor
how many sub basement do you need before you get to the underground lair?
What number comes between 1 and -1?
What if you have a huge, underground, villainous complex. I really don't have the room for sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-sub-basement on the lift control panel.
or....walk into a shop and ask for three mars bars. Does the assistant hand over 3 or 4 mars bars?
1,2,3
0,1,2,3
