Siegmeyer? you might find him inside Sens, he will be sat on a ledge by the ramp outside you encounter near the start. If he's not there i think you might have missed his story.
At this point Sieg "should" be in Anor Londo still unless Agnes let him out.
Other possible location is Blighttown but I'm not certain if he moves on from Anor Londo automatically.
Well, I'm at the end of the 'courtyard' where the cave start, is it near there? If so, then perfect, I will just run back and give what's his face his freedom.
I won't ask or google what the treasure is if it's worth it lol.
In terms of damage, I'm now at max then right? I got 40 dex and a +15 Uchigatana. I'm pumping up my vit a bit now, but will focus on endurance next and get that to 40.
Once that's to 40, what then?
If you are sticking with Dex + an unmodified sword I would go Int or Faith for a weapon spell, for a non-spell based character Sunlight Blade has the best scaling (meaning you dont have to level Faith higher than the 25 requirement), you get it from killing a secret boss in Anor Londo which requires a Ring found in the Catacombs.
A note for the final boss of Dukes, you "can" cut off his tail but honestly don't even try it solo, it is probably the most awkward and annoying thing to do in the game but REALLY easy with 2 people.
Also wish someone had told you not to kill Sif before you did the DLC but oh well.
Will dedivine it and upgrade it along the normal path.
