- 31 May 2009
Can the black box be disabled mid flight?
With a massive bomb, or an alien effector, possibly a massive emp or magnatron.
Else nope, and there should be two black boxes afaik.
And nobody has mentioned how long it took to find The Titanic yet.
Yes. There's a fuse board in the cockpit. If one of the pilots pulls the fuse for the FDR then it stops recording data.
Really?
Both of them?
Why on earth would this be a feature?
Not thinking about the black box recording as much as the beacon. Unless it completely disintegrated I'm struggling to understand why they haven't been able to locate, if not recover, it.
As well as possible sightings of wreckage, the search teams will be trying to find the aircraft's emergency locator transmitter (ELT) which is a location beacon.
However aviation experts say ELTs do not always work in the event of a major crash into water.
The plane also has a "black box" consisting of the cockpit voice recorder and the flight data recorder.
If immersed in water it should activate a "pinger" that can draw investigators to the location, although the signal cannot be detected over long distances.
Cheers. Was the pinger I was thinking of rather than the ELT. Makes sense if they have to be relatively close to receive a signalAs the BBC news says.
Its also not rear, took 9 days to find the wreckage of Adam Air flight 574
The french flight took a week and that was in the middle of the atlantic.
initial investigation was hampered because the aircraft's black boxes were not recovered from the ocean floor until May 2011, nearly two years later.
Cockpit reset under fault conditions.
If you've ever watched Aircraft Investigation, as I have, there's an episode covering this. The pilot was suicidal and before nose diving the plane into a river killing everyone on board, he sent the co-pilot out of the cabin, pulled various fuses, including the FDR, and then crashed the plane.
They are usually just two D batteries in my experience. recording all that they do for a month isnt too bad.
