With regards to the flight sim.
there are reports that the captain was also doing work for a flight sim company
Although that may have been discredited
Not heard of any reports like that.
And that the Radar has a % of accuracy and at the Altitude is way off
Radar doesn't give you altitude - it gives angle, range and doppler (although search radars will be doppler ambiguous). You can sort of work out altitude from that, but yes there will be errors. How big they are depends on the radar and where the target is.
Interesting theory about shadowing another plane... http://keithledgerwood.tumblr.com/post/79838944823/did-malaysian-airlines-370-disappear-using-sia68
Its an interesting theory, one question i have is just how close would the Malaysia plane have to get to the 777 before radar would detect it as a single plane, rather than two very close planes with one active transponder? I know that theoretically you could hide the Malaysia plane in the shadow of the 777 if there was just one radar, but if there is more than one radar station that could pick the planes up, this would be very difficult.
Pilots on other forums are saying that it couldn't actually get to 45'000 ft. And that the Radar has a % of accuracy and at the Altitude is way off
A sensible view of what might have happened from a pilot, looking at it from the pilot's view and discounting all the speculative conspiracy theories:
https://plus.google.com/106271056358366282907/posts/GoeVjHJaGBz
The plane has a certified service ceiling of 43,100ft, so no it would not be able to reach 45,000ft. The last time pilots stupidly tried to exceed an airliners service ceiling it destroyed the engines and the plane crashed.
The last voice comms to ATC from the plane (after ACARS has gone off), have they done any voice analysis to confirm it was the crew speaking?
Makes you wonder whether pilots should have the ability to disable the transponder. Maybe an automatic system would be best.
if an electrical fire started in the transponder electronics you would definitely want to turn them off in flight
*edit*
I'm too lazy to check, but does this story still fit with the most recent known flight path which has a left turn, right turn, then a further left turn in it
Great read that. Certainly makes a lot of sense.
