I've got the filco majestouch ninja (side printed) keyboard with cherry browns
I too have a Filco Majestouch with browns (although, mine's a TKL), and I absolutely adore the thing.
QPAD MK-80 died tonight after about 15 months useScroll lock LED is out as well as it not working. The numpad keys have been more and more temperamental in the past few months, now all my cursor keys as well as b/n and forward slash are dead. Guessing it's a goner? Bit gutted really, loved the QPAD but won't be buying another. Anyone else had the same issue?
Two of the LED's on my QPAD MK-80 have stopped working which is weird. The 'Fn' key and 'Enter' on the Numpad. Annoying as it's only 3 months out of warranty and are keys I hardly ever use (not that that would make much of a difference).
What to do? Qpad support any good?
Still in warranty mate get it sent back
Only one way to find out, i hope there are tho as i have same board![]()
Hi AzZ,
It seems like your LED soldering has
gotten loose and you would have to de-solder the LED and
replace it with a new one.
If the keyboard is under warranty my
best advice for you is to contact your retailer regarding
the warranty and have the whole keyboard
exchanged.
Filco has died.
It's a month out of warranty -typical for me - but I have a replacement USB cable on the way which should be the fix for it! Here's hoping.![]()
Just realised that the TKL version with reds has been discontinued, FFS. Time to look elswhere I guess - maybe a noppo choc mini?
It took a little while to get used to but it's lovely now, and I find it really shines in FPS games as it feels so much more responsive than your standard membrane keyboard.
