I use AG HD Wax at the minute and have some Extra Gloss Protection. Is it worth putting that over the Wax or not? I thought I'd read that putting a sealant over a wax will strip it (may be wrong).
Loving the look of that Sonax BSD - do people spray it onto the car after drying or before?
Going by a CYC post on DW, you can use it on a damp car.
I uses it after it had been dried. Not super slick to work, but anyone complaining about the application is a fanny. Just spray on sparingly, spread over panel with a MF cloth, then rub off until it's gone.
Then enjoy the rain when it comes
