- 21 Jul 2005
- Officially least sunny location -Ronskistats
LMAO Matt!
Guys, the problem has been solved thanks to Matts suggestion of the driver reinstall. Many thanks for your time.
Sorry for repeat but..........
Do all 290X cards have somewhere to connect a DMM to monitor voltage or is it only brand specials?
Kaapstad?
I think it is only special brands but if you post this question in 8 Packs section he will be able to tell you for sure.
Lightning does, and I'd assume all the non ref ASUS cards do
Word of warning on the Lightning though, they seem to throttle the amperage after 1.5-55v. I've only owned the Lightning personally but a few people have been able to get more out of ragging the reference ones. I didn't bother putting mine on water because of this. Was tempted to get a reference card after I DSRd it.
Good info MjFrosty. I was tempted with the Lightning, but went reference so I'm ok with that. I'm changing bioses atm. Trying "PT3" and "PT1" now and I've also got the ASUS bios as well. Using the default Gig bios I can bench at a reasonable-ish 1300/1500 on water. Going to chill it down a bit to see if there is anything more to play with. Here's hoping.......![]()
Tempted to buy 2 290X's for £270 each.
Both reference though...
My room is slowly getting warmer so I think that would be a bad idea.
Matt I need the opinion of your ears.
If I got two and downvolted them is it likely I would hear them over a noise cancelling headset?
