- 6 Aug 2009
- Wales
Awesome thanks for the help thingemajib
Seems that's not possible for me actually, my fault should have said that my server is provided by Gaming Deluxe.
I've searched the web for people trying to do the same thing but come up with nothing.
In your control panel there will be a mod settings line, basically just add @mod; @mod etc for whatever mods you want to run. You also need the @mod folder within the root of your arma install..
Cheers MarkeR, managed to sort it in the end![]()
One mod you need mate is
A3 Map Pack, has Chern, Taki etc all configured to be played within A3.. This will allow you to greatly increase the amount of missions that you can play..
http://forums.bistudio.com/showthread.php?170241-A3MP-ArmA-3-Map-Pack
Advanced Medical System (This will have Melbo screaming)
http://forums.bistudio.com/showthread.php?169030-XMedSys-Improved-Medical-System-for-A3
Enhanced realism
http://forums.bistudio.com/showthread.php?164304-TPW-MODS-enhanced-realism-immersion-for-Arma-3-SP
These are three which I would have no matter what.. For when you start building your own missions, you can use mod vehicles such as Konyo's beautiful Chinook
http://forums.bistudio.com/showthread.php?177084-Boeing-SOAR-MH-47E-ArmA-III
Any help needed, there are plenty of us willing.
You may want to rethink ACRE, and use Arrowhead radio. I have been told it is a lot lot better than ACRE at the moment. Plus it is intergrated into the medical system above.
http://forums.bistudio.com/showthread.php?169029-Task-Force-Arrowhead-Radio&highlight=arrowhead
None needed m8, just filter for EUTW and join.
[TFU] Thegoon84;26346893 said:Cant find it anywhere mate!!
Just started the last part of the campaign - Win.
Will I ever get to fly a heli in this damn campaign?
