120hz screen?
Yeah.
120hz screen?
Yeah.
FYI humbug and thefogo.
If you black screen its most likely the output going to **** caused by too much voltage (Doesnt have to be a dangerous amount of voltage). You can keep this from happening to some degree by lowering refresh rates to 60, if its only for benching then you might aswell run 30hz on your screen.
Rarely does RAM just make your stuff go black, its usually flickering.
If you black screen its most likely the output going to ****. You can keep this from happening to some degree by lowering refresh rates to 60, if its only for benching then you might aswell run 30hz on your screen.
I run a 60Hz screen, i have not had a Black Screen yet.![]()
Exactly, you might start seeing some though around 200mV, dont be scared though![]()
Nice, it worked. I got it to 1550.
Got a lower Firestrike score though lol
Yeah anything over 1500 seems to lower my score. Ah well.
My Elpida's go higher than your Hynix's. Its a crazy world we live in.![]()
Try bumping the voltage one or two notches. If that fixes it, then you know the problem.
are you setting power control to 20% that helps on some cards at stock
Any ideas on what i should try with my 290 PCS+ Overclock it not done it yet, got 3D mark can bench on that or unigine i think its gonna be a decent overclocker so..
Rangerjr1, you're my hero
1200/1500 @ +175mv, and perfect, no flickering, no artefacts...nothing, just perfect. and i broke the 12K score milestone.
Score: 9744
Graphics Score: 12141
http://www.3dmark.com/3dm/3129398
Jesus christ my jimmies...
Lol
Faster ram doesn't = more bandwidth. More bandwidth doesn't = faster ram. Bandwidth is the combination of ram and bus.
Only reason im replying to this is because sugarhell linked it to me.
Anyways.
Formula:
Bus width x RAM clock speed x 4 / 8 = Bandwidth
So in my case: 512 x 1650 x 4 / 8 = 422400mb/s or 422.4gb/s Bandwidth. So what happens when you increase RAM speed? Lets try.
512 x 1775Mhz (like my 290x bench) x 4 / 8 = 454400mb/s or 454gb/s. Oh look at that, RAM speed increased.
What happens if i lower the bus width?
384 x 1775 x 4 / 8 = 340800mb/s or 340gb/s. Would you look at that what a surprise RAM is now slower because the bus isnt as wide.
Faster RAM DOES equal more bandwidth, and bandwidth is measured in the amount of data it can move every second! More data it moves, the faster? I dont know.
