- 19 Feb 2012
Check the battery stats, what's using the most battery so far? If it's "Android system" then yes it will usually work. To do this, disable fastboot on your phone (in the power settings), then turn off your phone. Then after a few seconds, hold the volume down button, and press the power button. This will boot the phone into bootloader mode. Now use the volume buttons to select "Recovery" and use the power button to confirm. You'll see a black screen for a while but once you see the phone icon with a red triangle, press power + vol up at the same time to get the recovery options. Use the volume buttons to select "Clear cache partition" and confirm with the power button. Once that's down select "Reboot system" and it will boot your phone back to Android.
Does this wipe the phone like a factory reset or will everything be the same when I boot the phone back up?
it's odd.
