IIRC, it was dead pixels on a very expensive monitor.
Fair enough. Tbh I doubt I could even see the pixels on a 4K screen. 1440p is hard enough...
I've been getting this issue with the 290 Pro since I've changed from the 780 where my monitor won't wake from sleep correctly (This is the monitor in sleep not the system). It wakes and appears to be getting a signal, but it is only displaying a black screen. I'm using the latest beta drivers and have only had this issue since having the card.
Any ideas?![]()
Fair enough. Tbh I doubt I could even see the pixels on a 4K screen. 1440p is hard enough...![]()
Any ideas?![]()
Yes it happens to me sometimes, but not all the times. It's an issue which is under investigation. The temp solution, for me at least, is to turn your monitor off then on again and move the mouse and it picks up the signal. Or just stop the monitor from turning off...
Using Display port ?
Fitted my Sapphire 290 Vapor-X OC yesterday and it's fantastic. Cool looking card that's really quiet and performs really well![]()
+1
I've got mine clocked to 1100 core and 1550 memory stable. Not seen temps go past 74c so far
I think the core on my card might go a little further but the memory is about there. What clocks have you managed?
Any word from MSI yet moogleys?
I think I might just keep mine as I haven't had any problems so far..... ONly one blue screen, but I am not sure if that was because of the GPU or the poorly optimised wolfenstein game
Hopefully my temps will drop by a bit more once I get 2x140mm fans at the top and 2 better 120mm fans at the front of my case + a cooler running CPU.
I've not overclocked mine yet but I might give it a try in few days. I'm getting 72C on stock settings with 80% fan. Did you have fan running at 100%?
I think my fan speed tops out at about 65% at 74c. I do have my case near a window though which probably helps. Also I've got all my case fans going full chat.
I have just ordered a Sapphire 290 Tri-x OC....
I'm determined to get myself sorted with a 290...![]()
