Yeah it's raised quite a bit.
I have a Noctua NH-D14 and the backplate almost touches the heatsink of the cpu cooler. It was very hard to undo the pci-e latch.
I see, I have the same cpu cooler
between it and my current gpu psb is about 2-3cm's.Do you have it in crossfire with the msi (in your sig)?
Will heat the CPU no matter, unless you're a fancy fellow with his inverted motherboard tray.
They do look big!
