Ok, I've done the -31 on mV and will see how it goes. Any reason you've added 50% power?
Final question for now, I have 2 thermal compounds sitting here. AS5 and CM E2. Which would be better to replace the stock paste?
The reference cooler dissipates heat best at 94c believe it or not.
It may just be me but I thought a fan speed of 65% does seem a little high with a case fan virtually blowing directly on it. Do you have many case fans exhausting air?
Just looking to compaire when I get a 290 as I have a 650D with one 200mm in, one 200mm out and one 120mm out with a Noctua D14 CPU cooler taking up a bit of room![]()
Don't mean to pull you up, but i've never understood that...It dissipates the heat regardless of overall temperature, but by the fan spinning. Meaning if the core is at 80c and loading the core 100% with the fan spinning 100% its dissipating the same heat at 94c loading the core 100% and the fans spinning 55%.
Edit:
My top 290 does 1140 on the core with +0mv![]()
With that in mind, why would AMD even want to increase their operating temperatures to 95C? In short, to take full advantage of Newton’s Law of Cooling. Newton’s Law of Cooling dictates that the greater the gradient between a heat source and its environment, the more heat energy can be transferred. Or in other words, AMD is able to remove more heat energy from the GPU with the same cooling apparatus simply by operating at a higher temperature. Ergo a 290X operating at 95C can consume more power (operate at greater performance levels) while requiring no increase in cooling (noise) over what a 290X that operates at a lower temperature would require.
After one run on heaven my fan speed was 61% at 73c. Not bad considering it is rather warm today with that overclock.
I have 2 AF140's full speed at the front, one AF140 full speed at the back and two 120mm Gentle typhoons in the roof on my h100i running 50% speed ( They are the 1850rpm models).
This was with "Max" settings and 4xMSAA.
. A complete re-install of 14.6 drivers and it would run the Eyefinity profile but now wouldn't let me switch back to normal extended mode - either through a profile within CCC or Windows itself (Win + P).
am I likely to find a z77 board with more spacing between the PCI-e slots or is that about my lot?Just looked at your build, its stunning!
What temps are you getting now youve tweaked your fan profile?
I had a thread in general discussion but it seems to have died so rather than bumping it again I thought I would try here. My top msi gaming edition has been hitting temps of 90+ So I'm back down at 1 gpu for the time being however I want to get them both working if I can obviously. Now my motherboard is this am I likely to find a z77 board with more spacing between the PCI-e slots or is that about my lot?
It depends on what you want to spend. If you have a full ATX case, you could get a x16/x16 PCIE riser to move the 2nd card further away from the 1st, this would be your cheapest option.
LtMatt, thanks to your great advice got two 290s on their way![]()
Haven't fired up Titanfall for a while, do you still miss the minimap and half the HUD when playing on 3 screens, or have the devs finally got round to fixing that?
).So I had a quick google and I'm not sure how to go about doing this. From looking around it seems like after attaching the riser the card isn't going to fit back in the case properly?
In effect the card will need to fit into a spare expansion slot in the back of the case. Looking at your MB / Case combo it doesn't look possible as all of the expansion slots have a PCI-e slot (on the MB) lined up with them. The card will be fouled by either the x1 or bottom x16 slot.
You could possibly jerry rig something but I am not familiar enough with that case to know exactly what could be done.
Cool, keep us updated.![]()
