Does anyone else notice really obvious uniformity issues with this monitor? On mine, the centre of the screen is noticeably darker than the edges which is rather offputting :-\
Just a little update.
Received my replacement and all looks good so far.
No flickering or loss of signal
However the popping is still there but very faint compared to the other 2 monitors.
hi whyscotty I got rid of the popping sound by uninstalling the nvidia audio software![]()
I took your advice and did the same
But it doesn't bother me as it only does it the first time you turn the monitor on.
Sorry but the 1ms advertisement is a blatent attempt to get the gamers in. Input lag is strong with this one
im only getting 30hz on this monitor with 780gtx sli.
is there anyway to fix this?
