Should be an option saying fan speed you have to select to be in the osd.
lol, should have been more clear. I've enabled it, but its showing 0%/0RPM
Running at 1ghz with autofan on (around 48%) and getting 90-92c, that's if I take off my case front panel (750d) to let the fans more freely suck in air. Might have to add one to the bottom of the case or get higher airflow fans to address the temps better.
Under volting should be your friend, even while overclocking.![]()
Dunno, going to add an intake to the bottom of the case and see how it affects temps. Not a fan of undervolting can seem stable in some games then when you play something more demanding it can go to pieces.
Good choiceI very happy with this configuration and even in future will be base my next build around something.
Still looking for a resolution on why my fan speed isnt showing on the MSI AB overlay, despite me enabling it. Any ideas? It just shows 0%
