New essential Android apps thread
Office suite pro sure that was £7.99 the other day, free now
I got osp7 then spent some of my coins on photosuit so finally managed to spend some of my free coins too which in itself is a little bonus as I've been struggling to find stuff to spend them on, grabbed Plex too.
How do you see the free stuff, via the normal amazon android app, cant seem to see any offers? :(
This threw me a bit as well as I've never used Amazon's app before. It's not the Google Play Store Amazon app, you need to down load the Amazon App Store app direct from Amazon's website (it's an .apk file) to access the freebies.
Is there anyway to bypass the SKY GO app root issue?
It all depends on what ROM you are using. CM per chance? If so, then I think you will be stuck. Sky does suggest using some of the SU hide apps out there. Some people have had limited success with them.
Its the only reason I am still on stock rom on my One S
