Which games do you actually play?
I don't agree with the supersampling thing either but still games like Planetside 2, ARMA 3 don't run anywhere near 120fps constant.
Ah so you just play £A trash then, nevermind![]()
All my 100+ steam games are EA? Really dam
Not that i particularly care either way, but i side with Shanks because using Supersampling renders the images at higher resolution before downscaling them to your current resolution. 1080P + x4 AA should be possible to keep 60fps minimum in the majority of todays games. Crysis 3 might be an exception mind.
Well on your steam the only one you really seem to put any hours into is CS:GO and that runs at 120fps on a single GPU.
Check again. I complete games and stop playing them csgo just keep playing.
Not familiar with those games, so fair enough. Are they cpu limited games though? Cpu limited games are a different kettle of fish usually when you're talking about dual gpu performance maintaining 60fps minimum at 1080P.
Fair play then you seem to only play games you know will run at 120fps but there's plenty out there that the rest of us play that don't.
It's not about that though is it Mei, it's about saying every game you play runs at 120fps on max settings consistently which not many here are going to believe.
If he said I tweak the settings to get as close to 120fps as possible then yeah.
i dont understand this argue
if u enjoyed games at 120hz why wouldnt you be playing games at that?
why would you fire up sniper elite at 4xmsaaawavewillyaroundpointlesssetting
if you into fast paced fps, 4k is a downgrade right now, and maybe for a long time
Nvidia and the Acer 4K combo are the best experience with 4K gaming probably right now.
